8861 - User interface different ?
Hello I'm new to the Cisco community. I'm looking to know why is my User interface significantly different from what we see in all the product sheets? See attached versus what I see. I've searched in the settings and aside from wallpaper I can't customize anything... Am I missing something?
Other question, I've connected an iPhone via bluetooth, is it normal that address book won't sync at all ?
Thanks in advance.
You have MPP firmware, the screen shots are from the default firmware which register on Cisco CUCM
That might be the difference
JH
13 Replies 13
If it's about upgrading firmware... there is no tFTP settings in phone...at all !
Did you look through that thread..? Firmware was one of two ideas.
Yes I did, my issue is not the same, he’s talking about ringtones
You're not able to edit ringtones.
Let's start with what's in that thread and we can go forward from there.
I’m talking about the whole user interface and settings that are not
the same, nothing to do with ringtones...
What is the firmware and on what system are you registered?
JH
sip88xx.11-0-0MPP-7.loads
JH
What's the difference ?
MPP firmware allows Cisco IP phones to register on non Cisco PBX (Communication Manager)
https://www.cisco.com/c/en/us/products/collaboration-endpoints/ip-phones/multiplatform-firmware.html
Bye
Jan
Is it possible to upgrade to SIP v 12 on a CP-8861-3PCC ?
The latest mpp firmware is 11.0(0.7)
The 12 version is the enterprise Cisco SIP firmware which you need to connect to Cisco CUCM
As far as I know when your phone has MPP firmware you can't switch to Cisco enterprise firmware
Jan
