01-09-2019 12:58 AM - edited 03-18-2019 12:35 PM
cucm 11.0 , is there anyway just to change the expansion module language and keep the phone English?
01-09-2019 01:33 AM
Try to update user and network local on the phones' common device config OR Directly on Phone Page o English and Reset Phone.
If English option is not there then you may need to install the Locale in CUCM.
Haris
Please rate and mark correct.
01-09-2019 02:35 AM
hi,
I can choose English locale for the phone from phone page config , but my question, can I use English locale for phone and Arabic locale for module? both loacale installed on cucm but I just can change both for same locale , any idea?
01-09-2019 04:03 AM
This is not possible since the extension "takes" the settings from the main device and the only thing you can change is the "Phone Button Template"
G
01-09-2019 04:16 AM
This is not possible. Phone and Module will take same locale
