8875 MPP version of the phone
mixalisen
I was wondering if there is an MPP (multiplatform) version of  the 8875 phone. For example 8865 comes with the code 3PW or 3PCC. If it does, does someone knows the part number?
Thank you!
The data sheet implies this by omission, as @Ibrahim AlQumairi quoted, but I checked with the Cisco product management team to be sure. The 8875 does not support non-Cisco call control platforms that MPP phones have traditionally worked with as of today (September 2023). There are plans to add those capabilities but NDAs prevent me from sharing specifics publicly. If you intend to buy phones from Cisco through an authorized reseller I suggest reaching out to your Cisco account team for timing and further details. A sufficiently large order may even allow you to influence that timing.
6 Replies 6
Jonathan Schulenberg
The 8875 has a unified firmware build called PhoneOS; there are not MPP and Enterprise variants.
mixalisen
Thanks Jonathan,
So I guess it can work with a 3rd party PBX system, correct?
Was looking for this feature as well; mpp or perhaps Teams phone native support, no dates available for this yet?
As the Data Sheet of the CP 8875 Says:
Running on PhoneOS, the 8875 provides native support for Cisco Unified Communication manager, Webex DI, Webex for Broadworks and Webex Calling with one single firmware load. Customers have the flexibility to switch between platforms as they need while maintaining with a consistent user interface.
Thanks Ibrahim!
