06-20-2017 08:57 AM - edited 03-17-2019 10:37 AM
I am familiar with the "Always use prime line" setting on these phones. Is there a way to change "prime line" to line 2? Or another way to have outbound calls prefer line 2 instead? Thank you.
Solved! Go to Solution.
06-21-2017 04:27 AM
This is an expected behavior of SIP Phones, if you do not configure line 1 then it wont get registered as config file info for Line will be empty.
Find the below forum helpful
https://supportforums.cisco.com/discussion/12213011/8961-wont-register
Abhay
Kindly rate all helpful posts !!!
06-20-2017 09:24 AM
Hope this below link helps
https://supportforums.cisco.com/discussion/13218711/88xx-enhanced-line-mode-always-use-prime-line-features
Abhay
06-20-2017 12:04 PM
Thank you Abhay. That's sort of what I was looking for.
Do you know if there's any way to register a phone with line 1 unconfigured and line 2 configured? On 8800 phones they are unprovisioned until line 1 is configured.
06-21-2017 04:27 AM
Abhay
