01-23-2013 08:39 AM - edited 03-16-2019 03:19 PM
We're on CUCM 8.6.2 and Device Pack 8.6.2(22030)
I updated an IP 8945 SCCP test phone to firmware 9.3.2.11 and features such as Enhanced Message Waiting Indicator, and One Click to Home Screen don't function.
Do these features require CUCM ver 9?
Solved! Go to Solution.
01-23-2013 08:57 AM
Hi Crowley,
It looks to be supported on SIP only as well as 9.x
This appendix provides information about feature support for the Cisco Unified IP Phones 8941 and 8945 using the SCCP or SIP protocol with Cisco Unified Communications Manager Release 9.0.
The table provides a high-level overview of calling features and their support by protocol. This table focuses primarily on end-user calling features and is not intended to represent a comprehensive listing of all available phone features. For details about user interface differences and feature use, refer to the Cisco Unified IP Phone 8941 and 8945 User Guide for Cisco Unified Communications Manager (SCCP and SIP).
The guide is available at this URL:
http://www.cisco.com/en/US/products/ps10451/tsd_products_support_series_home.html
The specific sections that describe the features in the user guide are referenced in the following table.
Features | Protocol: SCCP | Protocol: SIP | For more information, see the following chapter and section in the user guide |
Calling Features | |||
Abbreviated Dialing | Supported | Supported | Calling Features, Speed Dial |
Agent Greeting | Supported | Supported | Calling Features, Agent Greeting |
Assisted Directed Call Park | Not supported | Supported | Calling Features, Call Park |
Audible Message Waiting Indicator (AMWI) | Supported | Supported | Voice Messages, Check for voice messages |
Audio Only Lock Icon | Supported | Supported | Calling features, Video Calls and Security |
Auto Answer | Supported | Supported | Calling features, Auto Answer |
Auto-pickup | Supported | Supported | |
Automatic Port Synchronization | Supported | Supported | |
Barge | Supported | Supported | Calling features, Barge |
Block external to external transfer | Supported | Supported | |
Bluetooth Handsfree Profile | Supported (Cisco Unified IP Phone 8945 only) | Supported (Cisco Unified IP Phone 8945 only) | |
Busy Lamp Field (BLF) | Supported | Supported | Calling features, Line status |
Busy Lamp Field (BLF) Pickup | Supported | Supported | Calling features, Line status |
Call Back | Supported | Supported | Calling features, Call Back |
Call Display Restrictions | Supported | Supported | |
Call Forward All | Supported | Supported | Calling features, Call Forward |
Call Forward All Breakout | Supported | Supported | |
Call Forward All Loop Prevention | Supported | Supported | |
Call Forward Busy | Supported | Supported | Calling features, Call Forward |
Call Forward Configurable Display | Supported | Supported | |
Call Forward Destination Override | Supported | Supported | |
Call Forward No Answer | Supported | Supported | Calling features, Call Forward |
Call Forward Notification | Supported | Supported | |
Call Park | Supported | Supported | Calling features, Call Park |
Call Pickup/Group Call Pickup/Directed Call Pickup | Supported | Supported | Calling features, Call Pickup |
Call Recording | Supported | Supported | Calling features, Silent Monitoring and Recording |
Call Waiting | Supported | Supported | Calling features, Call Waiting |
Caller ID | Supported | Supported | Your Phone, Buttons and hardware |
Caller ID Blocking | Supported | Supported | |
Calling Party Normalization | Supported | Supported | |
Cisco Extension Mobility | Supported | Supported | Calling features, Extension Mobility |
Cisco Extension Mobility Cross Cluster | Supported | Supported | |
Classic Ringtones | Supported | Supported | |
Client Matter Code (CMC) | Supported | Supported | Calling features, Client Matter Code |
Computer Telephony Integration (CTI) Applications | Supported | Some support (such as Call Park, MWI) | |
Configurable Call Forward Display | Supported | Supported | |
Custom Background Images | Supported | Supported | |
Device Invoked Recording | Supported | Supported | |
Direct Transfer | Supported | Supported | |
Directed Call Park | Supported | Supported | Calling features, Call Park |
Do Not Disturb (DND) | Supported | Supported | Calling features, Do Not Disturb |
Distinctive Ring | Supported | Supported | Phone applications, Ringtones |
Enhanced Message Waiting Indicator | Not Supported | Supported | Voice messages, Voice message identification |
Enhanced Version Negotiation with Unified CME | Not supported | Supported | |
Fast Dial Service | Supported | Supported | Calling features, Fast Dial |
Forced Authorization Code (FAC) | Supported | Supported | Calling features, Forced Authorization Code |
Group Call Pickup | Supported | Supported | |
Headset Sidetone Controls | Supported | Supported | |
Hold | Supported | Supported | Calling features, Hold |
Hold Reversion | Supported | Supported | Calling features, Hold Reversion |
HTTP Download | Supported | Supported | |
HTTPS Support | Not supported | Supported | HTTPS support |
Hunt Group | Supported | Supported | Calling features, Hunt Group |
iDivert | Supported | Supported | Calling features, Divert |
Incoming Call Toast Timer | Supported | Supported | |
Intercom | Supported | Supported | Calling features, Intercom |
Join | Supported | Supported | Calling features, Join calls into conference |
Join Across Lines | Supported | Supported | Calling features, Join calls into conference |
Line Status for Call Lists | Supported | Supported | |
Log Out of Hunt Groups | Supported | Supported | Calling features, Sign in and out of hunt group |
Malicious Call ID | Supported | Supported | Calling features, Malicious Call ID |
Maximum CTL File Size | Supported | Supported | |
Meet Me | Supported | Supported | Calling features, Meet Me |
Message Waiting Indicator | Supported | Supported | User options, Change voice message indicator setting per line User options, Change audible voice message indicator setting per line |
Mobile Connect | Supported | Supported | Calling features, Mobile Connect User options, Mobility settings |
Mobile Voice Access | Supported | Supported | |
Multiple Calls Per Line | Supported | Supported | Calling features, Multiple Calls Per Line |
Music on Hold | Supported | Supported | |
Mute | Supported | Supported | Calling features, Mute |
No Alert Name | Not Supported | Supported | |
On-hook dialing | Supported | Supported | Calling features, On-hook dialing |
One Click To Home Screen | Supported | Supported | Your Phone, Buttons and Hardware |
Other Group Pickup | Supported | Supported | |
Pause in Speed Dial | Not supported | Supported | |
PLK Support for Queue Statistics | Supported | Supported | Call features, Hunt Groups |
Plus Dialing | Supported | Supported | Call features, Plus Dialing |
Privacy | Supported | Supported | Call features, Privacy |
Private Line Automated Ringdown (PLAR) | Supported | Supported | |
Programmable Feature Buttons | Supported | Supported | Your phone, Buttons and hardware |
Programmable Feature Buttons as Softkeys | Supported | Supported | |
Quality Reporting Tool (QRT) | Supported | Supported | Call features, Quality Reporting Tool |
Redial | Supported | Supported | Call features, Redial |
Ring Setting | Supported | Supported | User settings, Change ring settings per line |
Ringer Volume Control | Supported | Supported | Your phone, Buttons and hardware |
RTCP control for video | Supported | Supported | |
Secure Conference | Supported | Supported | Call features, Conference |
Services | Supported | Supported | |
Services URL button | Supported | Supported | |
Shared Line | Supported | Supported | Call features, Shared lines |
sRTP Secure Video | Not supported | Supported | |
Monitoring and Recording | Supported | Supported | Call features, Silent Monitoring and Recording |
Speed Dial | Supported | Supported | Call features, Speed dial |
SRST Notification | Supported | Supported | |
SSH Access | Supported | Supported | |
Time-of-Day Routing | Supported | Supported | |
Transfer | Supported | Supported | Call features, Transfer |
Transfer - Direct Transfer | Supported | Supported | Call features, Transfer |
Time Zone Update | Supported | Supported | |
User Experience Enhancements | Supported | Supported | Applications, Call History Voice messages, Voice message identification |
Voice Mail | Supported | Supported | Voice messages |
VPN Client Support | Not supported | Supported | Phone Applications, VPN Client Support |
Widescreen Video Enhancement | Not supported | Supported | |
XSI Component API Support | Supported | Supported |
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
01-23-2013 08:57 AM
Hi Crowley,
Cheers!
Rob
-Springsteen
01-23-2013 09:05 AM
Great! Thanks for the help!!
01-23-2013 08:58 AM
Yes, in the RNs if you notice the "where to find more info" section, it all points to CUCM 9.0 documentation.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
