08-09-2011 08:12 AM - edited 03-16-2019 06:22 AM
Dear all,
I installed the 8961 using sip on CME 8.8, and I have configured the feature-buttons on the template which includes call pickup, call park and transfers, and these feature buttons can display on the screen. But when I use these buttons, I get the busy tone, that means these feature buttons don't work.
Are there any other setting steps for using these call features?
Kirin
08-09-2011 08:21 AM
hi,
the below link will give you complete details, go through the link and get back to me in case of any issues
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesoftk.html
hope this helps.
08-09-2011 09:00 AM
Hi Priya,
I have tyied to modify the softkey, but it doesn't display on 8961, so I have to use the feature-button to support the pickup. For feature-button it can display on the screen, but actually doesn't work!
Also I find the notes in the doc:
To modify the display of soft keys on SIP phones for different call states, perform the following steps.
Cisco Unified CME 4.1 or a later version.
•This feature is supported only for Cisco Unified IP Phones 7911G, 7941G, 7941GE, 7961G, 7961GE, 7970G, and 7971GE.
Kirin
08-09-2011 09:15 AM
hi,
the link which i previously sent you gives you information about which feature is supported on 8961 and which feature is not supported.
there are a few tables mentioned, which will give you a clear picture of compatibility.
08-09-2011 09:39 AM
Hi Priya,
Thanks, then how can I get the features run? any other steps I lost?
08-09-2011 09:53 AM
let me send you a few more links which will give you step by step configuration of cal park, call transfer.....
so that you can clarify the configuration once,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmepark.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrans.html
and below is some useful information regarding soft key configuration on cme
Cisco Unified CME uses the existing softkey command under voice register template configuration mode to control the controllable feature soft keys on phones. Cisco Unified CME generates a featurePolicy
08-10-2011 09:53 PM
Hi Priya,
I am sure the softkey can't be modified on 8961, I have configured the softkey under voice template configuration mode, but can't display on the 8961. Only feature-button configured under voice template configuration mode can display on the 8961 screen, but actually not active. when I press the pickup, busy tone will be heared.
02-02-2012 09:48 AM
05-10-2012 05:52 AM
I'm having the same issue with cme 8.8.
Feature button shows up and I can press it but once I press and dial the pickup group it gives me a busy signal.
Anyone figure this out?
07-20-2012 03:06 AM
Have you solved this issue?
i'm experiencing the same problem...
Best regards,
Matthieu
06-19-2014 11:22 AM
