hi,
we have an Cisco Callmanager Express with a ISM Unity Express Module.
At CME some IP Communicators configured and one hardware phone, a 8961. We know these phone running SIP.
If I push the message button at the IP Communicators I reach the voicemail.
If I push the message button at the 8961 I get a fast busy.
The DeBUG SIP means, that we have no CODEC negotiated.
Here the output:
SIP: (13641) Attribute mid, level 1 instance 1 not found.
Jul 21 07:32:01.462: //13641/5BBB9D05B547/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
Jul 21 07:32:01.462: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec: Unexpected VoIPCodec Type :
Jul 21 07:32:01.462: //13641/5BBB9D05B547/SIP/Error/sipSPI_ipip_update_call_entry:
Jul 21 07:32:01.462: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 13641
Jul 21 07:32:01.462: //13641/5BBB9D05B547/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
Jul 21 07:32:01.462: //13641/5BBB9D05B547/SIP/Error/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
Jul 21 07:32:01.462: //13641/5BBB9D05B547/SIP/Error/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Error/sip_iwf_sip_copy_channelInfo_to_sdp: We are either escalating, orno stream found for this m-line index:1
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Error/sipSPICodecTranscoder: Disjoint set & xcoder reservation failed. Disconnect call
Jul 21 07:32:01.726: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
Jul 21 07:32:01.726: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Error/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Invalid CCB/Data/Container
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Error/sipAddSipContainerToCallEntry: Unable to add passthru hdrs
to container
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Error/sipSPIAddSDPMediaPayload: Call Origination Failed: None of the selected codec from CLI is supported by SIP
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Error/sipSPIOutgoingCallSDP: Error with codec types on media line : 1
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Error/sipSPICreateOutboundSDP: Error in creating an SDP for the outbound call - Check for supported codecs
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Error/preprocessSetup: Error during outbound SDP creation
to container
Jul 21 07:32:01.726: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_spi_process_ccapi_event: CCAPI Event Preprocessor Failure
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x315D7170
State of The Call : STATE_DEAD
TCP Sockets Used : YES
Calling Number : 10
Called Number : 399
Source IP Address (Sig ): 192.168.100.12
Destn SIP Req Addr:Port : xxxx
Destn SIP Resp Addr:Port : xxxx
Destination Name :
Jul 21 07:32:01.726: //13642/5BBB9D05B547/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.100.12
Source IP Port (Media): 25782
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 47
Disconnect Cause (SIP) : 200
But I think I configured it correct:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h225-notify cid-update
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 3 hs-redundancy 2 fallback pass-through g711ulaw
h323
h225 signal overlap
modem passthrough nse codec g711ulaw
sip
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g723r63
codec preference 5 clear-channel
voice class h323 1
h225 timeout tcp establish 3
voice register global
mode cme
source-address 192.168.100.12 port 5060
max-dn 12
max-pool 10
timezone 23
time-format 24
date-format D/M/Y
voicemail 399
tftp-path flash:
file text
create profile sync 0005390733316005
network-locale DE
user-locale DE
overlap-signal
voice register dn 1
number 10
call-forward b2bua busy 399
call-forward b2bua noan 399 timeout 20
allow watch
pickup-call any-group
pickup-group 1
name 10
huntstop channel 1
huntstop
label 10
mwi
AND the dialpeer:
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:192.168.100.13
voice-class codec 1
no voice-class sip outbound-proxy
dtmf-relay rtp-nte sip-notify
no vad
Somebody can help?
find itself.
at voice register pool , where the phone residents, I configure codec g711ulaw and now it works.
