11-21-2006 09:33 AM - edited 03-14-2019 06:55 PM
Hello all,
This is driving me nuts! System is a 3825, 12.4(9)T1, CME 4.0. My innternational dial-peer is as follows:
dial-peer voice 9011 pots
description International dialing
destination-pattern 9011T
port 0/0/0:1
prefix 011
As soon as I hit the "0" in "90" it gives me a fast busy. If I change the destination pattern to 011T and remove the prefix, it works just fine. Here is a 'debug voip dialpeer' output when the pattern in 9011T:
Nov 21 17:17:26.738: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=2306, Called Number=, Voice-Interface=0x68AC5E78,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20004
Nov 21 17:17:27.418: //-1/FE8BC628BB6F/DPM/dpMatchPeersCore:
Calling Number=, Called Number=9, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=9
IRVCME01#
Result=Partial Matches(1) after DP_MATCH_DEST
Nov 21 17:17:27.418: //-1/FE8BC628BB6F/DPM/dpMatchPeersMoreArg:
Result=MORE_DIGITS_NEEDED(1)
Here are my dial-peers:
dial-peer voice 10 voip
description Voicemail Pilot Number
destination-pattern 2399
session target ipv4:172.29.22.230
codec g711ulaw
no vad
dial-peer voice 1000 pots
incoming called-number .
port 0/0/0:1
dial-peer voice 911 pots
corlist outgoing 911
description Emergency 911
destination-pattern 911
port 0/0/0:1
forward-digits all
dial-peer voice 9911 pots
destination-pattern 9911
port 0/0/0:1
forward-digits 3
dial-peer voice 1800 pots
corlist outgoing 18XX
description 1800-XXX-XXXX
destination-pattern 91800.......
port 0/0/0:1
forward-digits 11
dial-peer voice 1855 pots
description 1855-XXX-XXXX
destination-pattern 91855.......
port 0/0/0:1
forward-digits 11
dial-peer voice 1866 pots
description 1866-XXX-XXXX
destination-pattern 91866.......
port 0/0/0:1
forward-digits 11
dial-peer voice 1877 pots
description 1877-XXX-XXXX
destination-pattern 91877.......
port 0/0/0:1
forward-digits 11
dial-peer voice 1888 pots
description 1888-XXX-XXXX
destination-pattern 91888.......
port 0/0/0:1
forward-digits 11
dial-peer voice 97 pots
corlist outgoing local-call
description 7-digit dialing
destination-pattern 9[2-9]......
port 0/0/0:1
forward-digits 7
dial-peer voice 910 pots
description 10-digit dialing
destination-pattern 9[2-9]..[2-9]......
port 0/0/0:1
forward-digits 10
dial-peer voice 9411 pots
corlist outgoing services
description 411 Information
destination-pattern 9411
port 0/0/0:1
forward-digits 3
dial-peer voice 9555 pots
description 555-1212 Information
destination-pattern 95551212
port 0/0/0:1
forward-digits 7
dial-peer voice 9110 pots
corlist outgoing ld-call
description Long Distance dialing
destination-pattern 91[2-9].........
port 0/0/0:1
forward-digits 11
dial-peer voice 39 pots
description Overhead Paging
destination-pattern 7777
port 0/3/0
dial-peer voice 390 pots
description ANALOG TEST PHONE
destination-pattern 2541
port 0/1/1
dial-peer voice 20 voip
destination-pattern 2398
port 0/0/0:1
prefix 011
Any help would be appreciated...I'm hoping it's not anything glaringly obvious =(
11-21-2006 01:24 PM
It is werid, it should work.
Is anything to do the corlist?? I saw you have corlist at Local, LD, but not at International dial-peer.
Ken
11-21-2006 04:19 PM
I don't think it's anything to do with a corlist since it works if I change my dest pattern to 011T. I do indeed have a corlist, however i removed it from this dial-peer for troubleshooting purposes.
I'm stumped =X
