03-08-2016 07:09 AM - edited 03-17-2019 06:09 AM
All,
I have four POTS lines that connect into a router at one of my remote locations. When a 911 call is placed, the POTS lines are the preferred path to take. Is there a command on the router that I can execute that will show me the recent calls that traversed the POTS lines within a given time period with time stamps? A call history if you will. Thanks.
Solved! Go to Solution.
03-08-2016 07:47 AM
There's a "show call history voice" that will do what you want, but you'll probably want to change the retention time from the default with "dial-control-mib retain-timer 10080".
Gareth
03-08-2016 07:47 AM
Gareth
03-08-2016 08:18 AM
Thanks Gareth. That is exactly what I'm looking for. Best.
03-08-2016 11:50 AM
Last minute thought. What is the impact on storage with setting the retain-time to 10080 minutes? I did notice there is a max entries setting.
03-08-2016 08:16 AM
Your best bet would be to setup syslog and write things to it.
