Community Helping Community
156
Beginner
911 Calling
I have attached a screenshot of Cisco RTMT that shows the calls.  We receive calls that are labelled as "911", however, there is no answer.  More than likely it's a spoofed call, however, has anyone else run into this and if so, how did you remedy the situation?
2 REPLIES 2
Beginner
Re: 911 Calling
We had a similar issue however it was not spoofed calling.  It ended up being a bad FXO line that was randomly going off hook and hitting the 911 dial peer which the dial peer label 911 was inserted into the calling number.  The RTMT log was filled with the calling number coming from one of our gateways.
VIP Collaborator
Re: 911 Calling
The first thing I'd do is figure out for sure if the calls are coming in from the outside, or as @shleets proposed, if it is being accidentally generated inside your infrastructure.
Take a look at the CUCM trace files to see where the calls is coming from and/or the logs on your PSTN gateway.
Maren
Content for Community-Ad
FusionCharts will render here
