911 in Moscow Russia work ?
GM2020
Hi All,
I been asked to configure 911 in Russia, Moscow. But the call is failing. Please find the below logs.
My question is :
Will 911 work in Moscow, Russia?
Why is the call is automatically trying with Called Party Number i = 0x80, '11' stripping 9 ?
Can someone help me on this. Thanks !
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmoc001#
051413: Oct 13 11:58:53.917 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 84957870477
051414: Oct 13 11:58:53.917 UTC: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x050C callID = 0x848D switch = primary-net5 interface = User
051415: Oct 13 11:58:53.917 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x050C
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x2181, 'XXXXXXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '911'
Plan:Unknown, Type:Unknown
051416: Oct 13 11:58:53.995 UTC: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x850C
051417: Oct 13 11:58:54.015 UTC: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x850C
Cause i = 0x828100000000 - Unallocated/unassigned number
051418: Oct 13 11:58:54.015 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x050C
051419: Oct 13 11:58:54.074 UTC: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x850C
051420: Oct 13 11:58:54.077 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num XXXXXXXXXXX
051421: Oct 13 11:58:54.077 UTC: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x050D callID = 0x848E switch = primary-net5 interface = User
051422: Oct 13 11:58:54.077 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x050D
Standard = CCITT
Progress Ind i = 0x8183 - Origination address is non-ISDN
rOCWRUmoc001#
051423: Oct 13 11:58:54.156 UTC: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x850D
rOCWRUmoc001#
051424: Oct 13 11:58:55.589 UTC: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x050D
Cause i = 0x8090 - Normal call clearing
051425: Oct 13 11:58:55.651 UTC: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x850D
051426: Oct 13 11:58:55.652 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x050D
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmo
911 Config :
dial-peer voice 911 pots
description Emergency H323-SRST POTS dial-peer
translation-profile outgoing OUTPSTN
preference 1
destination-pattern 911
port 0/1/0:15
forward-digits all
dial-peer voice 9911 pots
preference 1
destination-pattern 9911
port 0/1/0:15
forward-digits 3
Slavik Bialik
Level 7
Level 7
In Russia the police isn't 911, but 102.
You can see the full dial plan according to Wikipedia:
https://en.wikipedia.org/wiki/Telephone_numbers_in_Russia
The emergency services in Russia are: 10X. (100-104)
Thanks for the reply. User in Moscow confirmed 911 is valid in the country.
I am in the process of checking with local vendor further..
Will keep this post updated on the outcome
If you are positive this should be allowed you need to contact the telco provider as currently getting "Cause i = 0x828100000000 - Unallocated/unassigned number" means the dialed number in not valid.
