9951 camera 50 Hz flicker
MARTIN STREULE
The 9951 cams seem not to have a 50 Hz flicker reduction option (or I did not find it)...
Does this option exist and - if yes - how can I enable that?
Thanks for any input - but not for the "move to a 60 Hz country" :-)
Cheers,
Martin
Cedric Van Labeke
Hi Martin,
There's no setting, but there's a built-in detection/correction mechanism that should overcome this but this could be CSCtj28632.
I'd like to recommend you to escalate this to TAC if possible for a fix or workaround or closer investigation.
Cedric
