Walkthrough Wednesdays
317
Highlighted
9951 dtmf issue on CUCM Version - 10.5.2.13901-2
We add new 9951 IP Phones in CUCM 10.5.2.13901-2.
In 9951 alone we have DTMF issues, in the same setup with 6921 ip phones we are able send DTMF digits.
active load on 9951 phone - sip9951.9-4-2sr2-2
6 REPLIES 6
Highlighted
Which type of call flow is being impacted?
If you try calling into something internal like a call handler in Unity Connection or a script on UCCX internally does it work?
Manish
Highlighted
ex, if I need login Unity connection, the PIN dtmf is not recognized, via  6921 able to enter pin number.
Highlighted
Is it a SIP integration with Unity Connection or SCCP? If SIP, what is the dtmf method configured on the SIP trunk. Can you get the detailed callmanager SDI traces from cucm for a failed dtmf scenario? Please ensure there are proper MTP resources available in MRGL of the SIP trunk
https://supportforums.cisco.com/document/144711/understanding-dtmf-negotiation-and-troubleshooting-sip-trunks
Manish
Highlighted
Unity Connection integration with SCCP.
In other IP Phone models  DTMF is working in the same setup, the issues is on 9951 IP Phones Model.
Highlighted
What is the firmware running on the phones? Also, check the bug below:
https://quickview.cloudapps.cisco.com/quickview/bug/CSCts24165
Aseem
(Please rate if useful)
Highlighted
We are running the below CUCM and Firmware for 9951, could please let me know this version is affected by BUG.
active load on phone - sip9951.9-4-2sr2-2.
Content for Community-Ad
