07-10-2011 09:50 AM - edited 03-16-2019 05:52 AM
HI Guys,
I have tried to register 9951 in in CME 8.5, and the phones are unregistered. here is the configuration snippet.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 nse version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.1.1.170 port 5060
max-dn 40
max-pool 42
load 9951 sip9951.9-1-1SR1<<<i have also given .loads and tried>>>>
tftf-path flash:
timezone 31
create profile sync 020131905538081A
voice register dn 1
number 8002
pickup-group 40
name User1
shared-line max-calls 6
label user1
voice register pool 1
id mac 1CAA.07E2.C2DE
type 9951
number 1 dn 1
cor incoming INTERNATIONAL default
presence call-list
dtmf-relay rtp-nte
no vad
tftp-server flash:dkern9951.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9951.9-1-1SR1.sebn
tftp-server flash:rootfs9951.9-1-1SR1.sebn
tftp-server flash:sboot9951.031610R1-9-1-1SR1.sebn
tftp-server flash:skern9951.022809R2-9-1-1SR1.sebn
tftp-server flash:sip9951.9-1-1SR1.loads
When i am Giving the command tftp-path flash:
i get the following error
CME(config-register-global)#tftp-path flash:
%Error deleting flash:/SIPDefault.cnf (File not found)
%Error deleting flash:/syncinfo.xml (File not found)
%Error deleting flash:/softkeyDefault.xml (File not found)
%Error deleting flash:/softkeyDefault_kpml.xml (File not found)
%Error deleting flash:/featurePolicyDefault.xml (File not found)
%Error deleting flash:/SEP1CAA07E2C2DE.cnf.xml (File not found)
These files though i can see in the flash
I am also attaching the show voice register global command. Any ideas why the phones are not registering
Solved! Go to Solution.
07-10-2011 01:52 PM
hi,
you need the command 'authenticate register' under voice register global
and username 8002 pass cisco under pool
07-10-2011 01:52 PM
hi,
