Beginner
9971 BLF SPEED DIAL
Dears,
By refering to the subject,It is not clear if blf speed dials is supported or not - as per cisco document it is supported; but we configure it for our expansion module for the 9971 it is not working (it does not show the status for the speed dials) Any specific configuration or it is not supported (We have call manager 8.6.2 and IP Phone firmware 9.3.X).
Regards,Karim
1 ACCEPTED SOLUTION
Hall of Fame Master
9971 BLF SPEED DIAL
Yes, it is supported. You need to ensure you have proper "Subscriber Calling Search Space" defined on the phone with the BLF defied which includes partition of the target DN.
HTH,
Chris
4 REPLIES 4
Hall of Fame Master
9971 BLF SPEED DIAL
HTH,
Chris
Highlighted
Advisor
9971 BLF SPEED DIAL
Beginner
9971 BLF SPEED DIAL
thanks for you reply Chris ,Aman I will double check this and update you tomorrows.
Beginner
9971 BLF SPEED DIAL
Yeah it was the subscribe CSS,thx
Content for Community-Ad
August's Community Spotlight Awards
