03-01-2016 01:26 AM - edited 03-17-2019 06:05 AM
Problem description :
Scenario
Any help or suggestion is kindly appreciated.
Wengkie K.
03-01-2016 03:27 AM
Hi Wengkie,
Is the issue also seen for calls between two 9971's on the same cluster? if yes, then it could be a phone specific issue. If the issue is only seen with calls over SIP trunk then you need to get the detailed callmanager service traces first to check if there is an issue with the signaling or some other error printed in the traces.
Manish
03-01-2016 06:15 PM
Hi Manish,
It doesn't happen when calling to other cisco endpoint.
I tried to call cipc, jabber on windows, telepresence server and all works well either video or audio.
I also tried to call from another 9971 phone, and the same problem occurs.
There is also a polycom mcu connected to VCS.
Video call to MCU works well.
I also tried to register other sip clients like x-lite and ekiga to VCS,
But call from 9971 to those endpoints is automatically switched to phone call, not video.
yet, the video capability is already enabled.
02-22-2018 07:57 AM
I have the same problem.
Prompt please whether it was possible to solve the given problem or to receive the additional information?
Thank you.
