12-30-2013 03:34 AM - edited 03-16-2019 09:02 PM
Dear Sir/Ma'am,
My name is Obaid, I am facing a problem in 9971 model phone.
Phone is not getting registered. In status, its showing "error verifying config info"
Can anyone help me?
12-30-2013 09:24 AM
What system are you registering the phone to?
Is the phone obtaining IP address, TFTP address?
Chris
12-30-2013 09:43 PM
8.5.1 version cucm,
yes, the phone is obtaining ip and all the remaining address(DNS, DHCP, TFTP)
12-30-2013 09:49 PM
Did you perform factory reset on the phone?
Is the phone defined in CUCM or are you using Auto registration?
What are you seeing in the status messages on the phone?
Is tftp service running on CUCM and is that the correct IP the phone is obtaining?
Chris
12-30-2013 10:01 PM
yes, I performed factory reset on the phone.
yes phone is defined manually by me and is not on auto registration.
In status message, "Error verifying config info"
yes TFTP service is running on cucm and the phone is obtaining correct ip
one more thing I want to tell is earlier 9971 phones got registered and are working good but yesterday
I got few new phones and this are give trouble and are not getting registered.
12-30-2013 10:22 PM
Ho Obaid,
what is the firmware u are using for working 9971 phones ?
Do u have enough license for new phones to register?
regds,
aman
12-30-2013 10:33 PM
How to check the license?
What I know is Go to System --- Licensing----license unit calculator (or) license unit report
12-30-2013 10:43 PM
Licensing issue would not cause phone registrTion denial, it would cause an error when attempting to configure the phone in CUCM. Are ITL and CTL certs deleted from the phone?
12-30-2013 10:50 PM
I really don't no whether CTL and ITL is deleted or not but am facing this problem for 5 phones.
01-05-2014 05:15 PM
Do those phones have DN's assigned on them? If not, the phone won't register.
01-05-2014 06:29 PM
Can you try deleting the CTL file and check again.
Go to Administration setting -> Reset settings -> Security setting -> Reset.
Br,
Nadeem
Please rate all useful post.
01-05-2014 08:17 PM
try to check whether IP phone is accesible from your Call manager to that port, have you checked it by changing the port.
