02-23-2011 07:29 AM - last edited on 03-25-2019 08:04 PM by ciscomoderator
I have a n issue with SIP SRST 7.2 ,where all my 9971 's not failing to register with 3945E SRST GW . I have SCCP phones and they register fine . I opened a TAC case and was told that the SIP bind interface needs to be same subnet as the Phones ,which I think is not a scalebale solution . Can anyone shed some light on this ,or have any ideas .
in the debug phones are using routers loopback address wihich is 192.168.X.X range and phones are in 10.133.X.X range . I have seen any large data canters where Vg are in the 10.X.X.X range to make SIP SRST work ...
03-01-2011 05:49 PM
Hi, Tahiryain
Would you please provide the TAC case number?
Rgds/Randy
04-01-2011 06:45 PM
Was this the case? Subnets?
04-04-2011 01:24 AM
Can you get the following debugs
debug ccsip messages
I would also recommend reading through
https://supportforums.cisco.com/docs/DOC-14828
/divin
PS:Rate only useful posts!
