07-26-2019 06:39 AM
I have three 9971 phones all registered to the same CUCM. They all have the same firmware and as far as I can see all three have the same settings include video enabled, etc. However, one of the phones cannot place video calls. The camera is working because I can see myself when I test it but it doesn't work when I call the other 9971s. What can I look for here?
Diego
Solved! Go to Solution.
08-02-2019 05:52 AM
I removed the phone from CUCM, did factory reset and after adding back in it is working.
Thanks all,
Diego
07-26-2019 07:30 AM
I have run in to this issue before and the fix was to remove the camera and reseat it.
07-26-2019 09:35 AM
Worth a shot. I'll try it and let you know.
07-29-2019 04:46 PM
Well I removed the camera from the non-working phone and installed on a working phone and it worked. Moved back to "bad" phone and still no go. Factory reset of bad phone did not work either. I am going to delete the phone and recreate using a working phone to see if that helps.
Diego
07-30-2019 04:19 PM
are these phones in the same devicepool and region that has video bandwidth allowed between phones?
08-01-2019 08:59 AM
The problem phone is in a different pool but I moved it into the same pool with the working phones and it did not make a difference. Thx
08-01-2019 05:01 PM
in that case dont waste too much time on it and RMA it, so it can be replaced under maintenance
08-02-2019 05:52 AM
Thanks all,
Diego
