01-20-2017 01:30 AM - edited 03-17-2019 09:15 AM
Does the power connector for the power supply of the 7800/7900 also connect to the SX20?
I'm aware that different power supplies are necessary, but I'm interested in the actual connector compatibility.
As a side note, does anyone know the name of the connector type for the 7800/7900 phones?
01-20-2017 01:56 AM
Hi Nadav,
For 78XX
Cisco power injector |
● The IP Phone 7811, 7821 and 7861 are compatible with Cisco Unified IP Phone Power Injector (CP-PWR-INJ), and 7841 is compatible with Cisco Aironet Power Injector (AIR-PWRINJ5=).
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7800-series/data-sheet-c78-729488.html
So 78XX would use CP-PWR-CUBE-3 which is backwards compatible with 79XX series, see below
http://docwiki.cisco.com/wiki/CP-PWR-CUBE
http://www.ciscopowercube.com/
BUt not SX20 see below
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-sx20-quick-set/data_sheet_c78-688342.html
(Rate if it helps)
JB
01-22-2017 12:04 AM
Hi Jitender,
I'm not asking about the power cube compatability but rather just the connector (the part that connects the powercube to the SX20). I'm interested if it's the same connector :)
