06-04-2013 01:26 AM - edited 03-16-2019 05:41 PM
Hello all!
I have PBX Aastra MX-ONE TSW which is connected to Cisco 2651xm via E1 PRI. So, Cisco2651xm is connected to Asterisk 11.2.1 via SIP trunk.
Cisco 2651xm has ip address 172.26.18.200
Asterisk has ip address 10.2.210.13
I can to make call from softphone 4092@10.2.210.13 in Asterisk to telephones 1312@172.26.18.200 Aastra MX-ONE successfully. But, I cannot to make call from Aastra telephones to Asterisk softphones. I recieve busy in telephone.
Cisco config:
Router#sho run
Building configuration...
Current configuration : 2126 bytes
! Last configuration change at 11:52:47 UTC Tue Jun 4 2013 by culture
version 12.4
hostname Router
boot-start-marker
boot-end-marker
card type e1 1 0
no logging console
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type primary-qsig
voice-card 1
voice call carrier capacity active
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
redirect ip2ip
signaling forward rawmsg
sip
no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
archive
log config
hidekeys
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.26.18.200 255.255.255.0
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
isdn global-disconnect
isdn contiguous-bchan
isdn bchan-number-order ascending
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.26.18.10
no ip http server
no ip http secure-server
control-plane
voice-port 1/0:15
dial-peer voice 1 pots
description *Aastra MX-ONE*
destination-pattern 1312
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 5 voip
description *to Asterisk*
destination-pattern 4092
voice-class codec 1
session protocol sipv2
session target ipv4:10.2.210.13
session transport udp
dtmf-relay rtp-nte
gateway
sip-ua
sip-server ipv4:10.2.210.13
line con 0
line aux 0
line vty 0 4
exec-timeout 30 0
logging synchronous
login local
transport input telnet
end
When I try to make call from telephone Aastra 1312@172.26.18.200 to softphone Asterisk 4092@10.2.210.13 i recieve these debug messages:
Jun 4 12:18:36.442: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4092@10.2.210.13:5060 SIP/2.0
Via: SIP/2.0/UDP 172.26.18.200:5060;branch=z9hG4bK3733
To: <sip:4092@10.2.210.13>
Date: Tue, 04 Jun 2013 12:18:36 GMT
Call-ID: B74918DF-CC4711E2-9EC98019-37A47AC2@172.26.18.200
Supported: 100rel,timer,replaces
Min-SE: 1800
Cisco-Guid: 3074740581-3427209698-2152333329-2481374176
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: <sip:1312@172.26.18.200>;party=calling;screen=yes;privacy=off
Timestamp: 1370348316
Contact: <sip:1312@172.26.18.200:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 286
v=0
o=CiscoSystemsSIP-GW-UserAgent 9478 9141 IN IP4 172.26.18.200
s=SIP Call
c=IN IP4 172.26.18.200
t=0 0
m=audio 17184 RTP/AVP 8 0 101 19
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
Jun 4 12:18:36.454: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 172.26.18.200:5060;branch=z9hG4bK3733;received=172.26.18.200;rport=55715
To: <sip:4092@10.2.210.13>;tag=as00007b29
CSeq: 101 INVITE
Server: Asterisk PBX 11.2.1
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces
Proxy-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="000024e0"
Content-Length: 0
Router#
Jun 4 12:18:36.458: //291/B744D165804A/SIP/Error/sipSPIHandleAuthChallenge: Error getting credentials
Jun 4 12:18:36.458: //291/B744D165804A/SIP/Error/act_sentinvite_new_message: Error handling AuthenticationChallenge
Jun 4 12:18:36.458: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4092@10.2.210.13:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jun 4 12:18:37.928: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.26.18.200 SIP/2.0
Via: SIP/2.0/UDP 10.2.210.13:5060;branch=z9hG4bK00003cfd
Max-Forwards: 70
From: "asterisk" <sip:asterisk@10.2.210.13>;tag=as00007a43
To: <sip:172.26.18.200>
Contact: <sip:asterisk@10.2.210.13:5060>
Call-ID: 00003dc200001ec4000010cc00002ebd@10.2.210.13:5060
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX 11.2.1
Date: Tue, 04 Jun 2013 08:18:24 GMT
Supported: replaces
Content-Length: 0
Jun 4 12:18:37.944: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.26.18.200>;tag=19D04B0D-26CB
Date: Tue, 04 Jun 2013 12:18:37 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 OPTIONS
Supported: 100rel,replaces
Accept: application/sdp
Router#vent
Content-Length: 170
v=0
o=CiscoSystemsSIP-GW-UserAgent 7433 1229 IN IP4 172.26.18.200
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 4 2 15 3
I don't understand these debug-messages:
Received:
It seems to me number 1312 tries to register on Asterisk. What for? Can anyone to take me some advise? Thx.
06-04-2013 01:44 AM
Router#sho ver
Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(25a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 22-May-09 21:06 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Router uptime is 5 days, 42 minutes
System returned to ROM by reload at 11:55:25 UTC Thu May 30 2013
System restarted at 12:00:38 UTC Thu May 30 2013
System image file is "flash:c2600-adventerprisek9-mz.124-25a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2651XM (MPC860P) processor (revision 3.1) with 253952K/8192K bytes of memory.
Processor board ID FOC08310NX3
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
31 Serial interfaces
2 Channelized E1/PRI ports
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
06-04-2013 05:06 AM
I sniffed traffic from Cisco2651-port in time with call from 1312 to 4092. I see that request 407 Proxy Authentication Required comes from Asterisk 10.2.210.13. But it conflicts with debug-messages from cisco:
Received:
To: <4092>;tag=as00007b294092>
