08-30-2015 07:26 AM - edited 03-17-2019 04:08 AM
I got two DX650, one can access all google services and the other do not have Google Play (disappeared or what) within listed applications.
How can I activate it or restore it as the other DX650? I can access all other applications but this one I can't? I've tried to manually install apk file for Play store but DX650 requests to enable 3rd party app from settings which I can't find on phone settings!!
Any idea?!
Solved! Go to Solution.
08-30-2015 07:30 AM
Because that setting it's in the CUCM config, not on the phone, change your CUCM config and then test.
08-30-2015 11:41 AM
Just to add clarity: you need to change the Device UI Profile parameter to Enhanced on the Device Configuration page. It is in the Product Specific Configuration Layout section.
08-30-2015 07:30 AM
08-30-2015 11:41 AM
08-30-2015 07:39 PM
[+5] to Jaime and Jonathan.
You can refer the disucssion
https://supportforums.cisco.com/discussion/12569456/dx-70-and-dx80-setup-assistant-option
regds,
aman
08-31-2015 02:36 AM
