Access Google Play on DX650
Mohammad Azzeh
I got two DX650, one can access all google services and the other do not have Google Play (disappeared or what) within listed applications.
How can I activate it or restore it as the other DX650? I can access all other applications but this one I can't? I've tried to manually install apk file for Play store but DX650 requests to enable 3rd party app from settings which I can't find on phone settings!!
Any idea?!
2 Accepted Solutions
Jaime Valencia
Because that setting it's in the CUCM config, not on the phone, change your CUCM config and then test.
java
if this helps, please rate
Just to add clarity: you need to change the Device UI Profile parameter to Enhanced on the Device Configuration page. It is in the Product Specific Configuration Layout section.
Jaime Valencia
java
Jaime , Jonathan Thanks for help, it is working fine now.
