11-29-2007 02:44 PM - edited 03-15-2019 07:30 AM
I have only had experience with newer 7961G phones. My experience was to simply make data and voice vlans access vlans on the switch, and the switch uses cdp to place the phone and pc in the correct vlans.
I have alot of 7941 phones and most of the switch configs have the ports forced to trunk with dot1q, in addition to access data and voice vlans. Is this neccessary with these phones? thanks
Solved! Go to Solution.
11-29-2007 03:18 PM
No, the same acces+voice vlan config should work for all phone models.
11-29-2007 03:18 PM
11-30-2007 08:09 AM
Thanks for the sanity check.
11-30-2007 08:18 AM
You are welcome, thanks for the nice rating and good luck!
