Accessing a Cisco DX650 via HTTP on a pc
kgilkes92
A tac engineer recently asked me to provide access to a DX650 via http from a pc. How do I do this?
Jaime Valencia
He might be referring to just enable the web access on the device and then be able to browse to that IP.
java
if this helps, please rate
Jaime Valencia
java
how do you enable web access on dx650 without using CUCM.  thanks
hothma1
Hello.  How did you solve the above issue?  Thanks
