02-15-2024 03:13 AM
After resetting the phone, it asks for an activation code or service domain.
From what I found out, I need a cfg.xml file but unfortunately I don't have anything like that. The phone is connected directly to the cisco switch. Where can I find such a sample cfg file or some standard one?
And I just wanted to update the software
Thank you for your help
02-15-2024 03:49 AM
If you wanna register them to CUCM, then search the forum for old post.
This topic has been asked so many times here.
02-15-2024 03:52 AM
I've already read that, but I don't have CUCM.
02-15-2024 04:02 AM
But you added a tag "CUCM" ^^
Which PBX do you have?
02-15-2024 04:05 AM
I don't have any PBX.
I would like to upload configuration files via tFTP
Sorry for the incorrect tag
02-15-2024 04:17 AM
What you mean, you don't have any PBX?
Without a PBX, the phone is useless ...
02-15-2024 04:22 AM
If you don’t have any PBX, let’s explore what you intend to do with this phone. Here are some considerations based on the context:
02-15-2024 04:20 AM
I wanted to configure the phone for VoIP (SIP) calls
02-15-2024 04:57 AM
And how do you want to make VoIP calls without a PBX?! --> I'll answer it for you: it doesn't
Maybe you should first learn, how VoIP works ...
02-15-2024 12:10 PM - edited 02-15-2024 12:11 PM
Pretty harsh. Your replies do not add value.
02-15-2024 05:04 AM
Of course you're right
My internet service provider has a virtual PBX.
Currently, I am stuck with updating the software due to lack of activation, hence my questions.
Thanks a lot for your help
