active directory sync
Maheshwar Tayal
Level 4
Level 4
As per documentation for CUCM and AD Syncronization,
All existing Cisco Unified CM end-user accounts are deactivated.
Will this be happening on every sync cycle or only first time.
Can we define Multiple synchronization cycles in a day say 4 at interval of 6 hours.
5 Replies 5
Ayodeji Okanlawon
The very first time you enable AD sync, all end users will be deactivated. This happens only once you enabled AD sync. Once AD sync is enabled you will not be able to add end users in CUCM, rather all users will be imported from AD.
You can define your syncronisation interval under the LDAP directories
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Unless you're running CUCM 9, on which you can have AD and still create users.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jamie, (+5),
I dint know this is now available on CUCM 9.0. Thats nice to know
Do we have CUCM 9.0 document which can provide some details, what is supported as answer is not very clear
You can find this information here. before CUCM 9.0 once you have AD sync enabled, you cant add users locally. However in CUCM 9.0, you can add users locally and also have AD sync. That means that when AD sync is enabled, CUCM will not mark your users inactive
LDAP and Manual User Support
Prior to CUCM 9.0
 Enabling LDAP sync would prohibit adding local users
 End user to be used by CUCM must be defined on AD and synched
 Extra users could trigger extra CAL’s on the MS AD
With CUCM 9.0
 Administrator can have both LDAP sync users and locally defined users
 Ability to modify local users and roles assigned to LDAP users
 Deleting LDAP synch will mark users synced for deletion (garbage collection)
 Administrator can convert an LDAP user to a local user
 User status field is used to differentiate between the Local user and LDAP Synchronized users
https://learningnetwork.cisco.com/servlet/JiveServlet/previewBody/15753-102-1-60993/CUCM%209%20New%20Features.pdf
