08-28-2015 12:27 AM - edited 03-17-2019 04:07 AM
Team,
We have got CUCM 7.1.3.32900-4 at one of our sites. We have been reported that Conference calls are not working since morning. I have verified the Media Resource Group and found all the resources were selected (Software CFB & Hardware CFB). Then i have restarted the IP Voice Media Streaming service from Unified Serviceability. But no luck. So as soon as soon as we hit Confrn softkey, newly added call is getting dropped. By the way I have checked Conference in Service Parameters and found to be good. CUCM has been restarted 356 days before. Need to get Conference get going at this site. Please find the Conifg below in my voice gateway.
sccp local GigabitEthernet0/0
sccp ccm 10.X.X.X identifier 1 priority 1 version 7.0
sccp
sccp ccm group 2
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 2 register Hardware_CFB
sccp ccm group 1
description transcoding resources
associate profile 1 register au-sydney
dspfarm profile 1 transcode
description transcoding resources for internal conferences and ACD calls
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 8
associate application SCCP
dspfarm profile 2 conference
description Conference resources for internal conferences and ACD calls
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
Need your expert advice, how to proceed further.
Solomon
Solved! Go to Solution.
08-28-2015 04:22 AM
Is 10.204.14.5 your CUCM server IP? How many conference bridges due you have in your MRG?
Try to keep one at a time and test.
What codec is being used by all participants. Any transcoding required
08-28-2015 03:57 AM
From your router share the output of sh sccp and show dspfarm all
08-28-2015 04:00 AM
Hi Mohammed,
Please find the output. My Question over here is, even internal calls fail as soon as I initiate Conference, which makes me annoy.
AU-Sydney-VGW01#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
IPv4 Address: 10.204.14.5
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.204.14.11, Port Number: 2000
Priority: 1, Version: 7.0, Identifier: 1
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.204.14.11, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 16, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Conferencing Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Profile Identifier: 2
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
TLS : ENABLED
AU-Sydney-VGW01#sh dspfa
AU-Sydney-VGW01#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description : transcoding resources for internal conferences and ACD calls
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 8
Number of Resource Available : 8
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 2, Service = CONFERENCING, Resource ID = 2
Profile Description : Conference resources for internal conferences and ACD calls
Number of Resource Configured : 2
Number of Resource Available : 2
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 2 26.7.0 UP N/A FREE xcode 1 - - -
0 2 26.7.0 UP N/A FREE conf 2 - - -
Total number of DSPFARM DSP channel(s) 10
08-28-2015 04:22 AM
08-28-2015 04:57 AM
10.204.14.11 is CUCM IP and 10.204.14.5 is MGCP Gateway.
Currently in the selected MRG, I have included both Software and Hardware Conference Bridges.
Basically CUCM has been deployed in Australia. 30 odd Cisco 6921 IP Phones registered to CUCM in AU has been placed in Thane, Mumbai. Currently Issue is happening at Thane. So with in Thane, we are using G711 and Between Sydney & Thane G729. We do have Hardware Transcoder included in to the MRG.
As you have mentioned I will include one CFB at a time.
Solomon.
08-28-2015 05:12 AM
Finally Conference Call worked, after I remove Software Conference Bridge from MRG. Currently only Hardware CFB has been included. I will let this setup remain for the next couple of days. But problem over with this is, I have configured only two sessions for this Profile in Gateway. So that at any point of time, only two Conference Calls can be made possible, where as with Software CFB we can have up to 48 Conference Calls as per Service Parameters. Please share some light on this.
Solomon.
