03-27-2013 10:24 AM - edited 03-16-2019 04:29 PM
Problem is as follows: User on a registered phone on the network conferences a remote user on an outside line (cell phone or land line--both tested). The user on the cell phone/land line is disconnected exactly 30 minutes after the call is nailed up. This behavior can be reproduced 100% of the time by simply conferencing in any user on an outside line using ad-hoc conference. Is there a timer somewhere that is configurable?
Thanks!
03-27-2013 10:27 AM
Are you using ISDN or SIP?
Yosh
03-27-2013 11:40 AM
SIP, thanks!
03-27-2013 12:10 PM
If you have a firewall in between your CUBE or WAN connection I would verify that it is not resetting or re-establishing the connection. Sometimes the sessions are re-established and it can cause these kinds of issues.
Yosh
03-28-2013 07:29 AM
We found a SIP timeout parameter in the ASA and adjusted it. Will monitor and report back results.
03-28-2013 07:42 AM
Sounds good let us know how it turns out.
Yosh
04-02-2013 09:16 AM
That didn't resolve the issue. I'm going to continue looking for layer 3 interruptions.
04-02-2013 09:54 AM
It is not due to layer 3.
It is due to SIP timouts, if you search you will find many threads with the same issue, some have found a solution, some don't.
