Customer has an older 4.2 system with AD integration. They are asking if there is any way to change the field in AD that the plugin uses for displaying the telephone number in the Corporate Directory from the TelephoneNumber field to the IPPhone number field.
I've not been able to locate any documentation, Cisco or otherwise, on this. My belief is that it's likely hard coded, but I'm curious if anyone else has researched this and found anything out.
Yes, I'm aware this is an EOL product. That's a different discussion we're having with the customer. Looking for any information that may be available on this particular problem. We were going to break the AD integration and go back to just using DC to deal with it, but found that when you break the AD integration, the DC directory goes back to where it was prior to the original plug in installation....the data isn't copied back. This is a huge issue, and we're looking for options to resolve it.
