I am setting up an AD LDS configuration for two domains in a LAB environment. After some struggles something starts to work. Using ADSI Edit I see the users from the two domains, so now CUCM has to connect to AD LDS.
I have disabled SSL as described in the This Guide After deleting the existing AD Directories (which disabled the end-users) I created new AD LDS directories. On requirement is to create a filter with objectclass=userProxy. But after a sync the end-users stayed disabled. When I removed the filter and synced again, all users from the two domains became Enabled. Not sure if this is correct
The main issue is the authentication, this doesn't work. Using wireshark and sniffing on port 50000 (AD LDS co-installed with AD) I can see there is a successful bind request, but jabber and ccmuser page say that authentication failed.
Any idea what could be wrong? Is the LDAP filter a requirement? Maybe in a previous step I did something wrong
Jan
