Add a Route Filter
pharden
i have a route fillter blocking 1 9XX calls. i would like to add information calls. i.e. (XXX)555-1212. without adding each area code to one RF.
Chris Deren
Instead of building a route filter for this it would be very simple to add matching route pattern: 9.1XXX5551212
HTH,
Chris
gmoeller1
If you were to use a filter, couldn't you just set: Area-Code "Exists", Long-Distance-Code "Exists", Office Code == "555", and Subscriber == "1212"? I haven't had the opportunity to test, but believe that should work.
