05-23-2021 06:04 AM
Greetings,
I'm trying to add expansion module CP-8800-A-KEM on CP-8851. Call Manager version is 11.5.
It doesn't give any light at all. Phone Active load is sip88xx.12-6-1-0001-668.
In Expansion Module : it shows
BEKEM-36-Button Line Expansion Module
ONE COLUMN Display for KEM is DISABLED ( as i have 2 column 14 line module)
I have tried power Negotiation - Enables/Disabled both.
Kindly advice
Solved! Go to Solution.
05-23-2021 06:51 AM
BEKEM and A-KEM are two product. if you have A-KEM you need to selected CP-8800-Audio on CUCM. if its BEKEM select that.
if you don't see CP-8800-A on drop down you might need to install the device package.
05-28-2021 11:57 PM
Hi Nithin,
Sorry for delayed response, actually I was waiting for software. I have tried it in LAB and it works.
Thank you for your support.
05-23-2021 06:51 AM
05-28-2021 11:57 PM
Hi Nithin,
10-04-2022 09:26 AM
Hi, Nithin
where can i download the device package? i need have a support contract or i need to buy it. Now our support contract is expired.
