Walkthrough Wednesdays
4130
mhassani
Beginner
Add DNS server to CUCM
I'm trying to add a DNS server to a running CUCM using the CLI command "set network DNS primary" and the command is unsucsseful with an error "internal CLI Error"
I have CUCM 7.1(5) can any one help on this issue
3 REPLIES 3
nitsinha
Enthusiast
Try deleting the DNS server entry first and re-entering it.
delete dns
Nitesh
PS:Pl rate helpful posts
nitsinha
Enthusiast
A DNS server change will restart the network service. Please check this bug and make sure you dont hit this after a DNS entry change
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth09430
Nitesh
Thank you I will check this and let you know by the way I don't have DNS configuration on the CUCM
So this is the first time we will be adding dns to this server
Content for Community-Ad
Spotlight Awards 2021
