03-07-2018 01:34 AM - edited 03-17-2019 12:21 PM
Hello, I added 7811 phone to the CME and gave him dn 55553 and I am trying to add a route pattern on CUCM that match just that phone but it can't accept it as 55553
It accepts only when I put 5555x but I am afraid to cause a problem or loop as I have a random dial plan
The error say (Add failed. Cannot insert or update pattern. A DN exists with the same pattern and partition.)
Solved! Go to Solution.
03-07-2018 02:37 AM
can you check your route plan report and search for 55553 and see if its already there, if so, delete it and add the router pattern again.
03-07-2018 02:37 AM
10-26-2018 08:25 AM
please de-associate the DN, that resolved my issue.
06-12-2020 05:19 AM
This was really helpful
Thanks a lot for the post
04-24-2023 04:41 PM
I ran into this same issue and deleting the DN allowed me to setup the translation pattern.
Thanks!
04-14-2023 02:10 PM
hola revisa si no tienes en hount pattern algo configurado en la ext o en translations pattern por ahi esta el tema saludos....
