Add picture as background on ip phones
abd88elhak
i'm using CUCM 10.5 and i would like to make the picture of our company as background on ip phones
i have this phone's :3905,7821,7945,7962 and 7975
please could you please give me the steps and the software needed to configure that
regards
Jaime Valencia
Look at the administration guide for each model on CCO and if it's supported, you'll find the instructions there.
Otherwise, simply search CSC as this has been asked plenty of times before and all you need has been discussed thoroughly.
java
if this helps, please rate
i have followed the link given above and i configured successfully two pictures as background on 7945 phones
i have also other phones 7975 and 7962
i would like to,know if i want to configure the same pictures on the other phones i have to follow the same steps (Create two filles .Png and file xml :List.xml)
then i will have 3 xml files named List .xml ???????
please help me
regards
Different phones have different screen resolution/size, so yes, depending on the models you have, you'll end up with several different List.xml and .pngs of different size per model.
Just a different directory based on the image size
java
Terry Cheema
Refer to here, as per Jaime's post this has been covered many times and a simple search should yield you sufficient results.
https://supportforums.cisco.com/document/44191/how-modifychange-background-image-ip-phone-new
https://m.youtube.com/watch?v=lRsRfte1YyM
https://supportforums.cisco.com/discussion/12197616/changing-background-image-all-phones-over-common-phone-settings
-Terry
