791
maqsood ahmed
Beginner
Add-search failed in cucm 6.1.4
i have this issue in cucm 6.1.4 , in two cluster envirnment.  when ever i add or search phone in cucm i get this error
"dd failed. Invalid distribution format found for pkid"  or
"Error occurred while retrieving information from database. java.sql.SQLException: Invalid distribution format found for pkid "
but , i can add css/patition/and device pool  with no problem
the replication is good with number "2" on both pub and sub  .
any quick response is appreciated
2 REPLIES 2
bvanturn
That does not sound health. A few things you could try:
- check if this is happening on pub and sub
- verify the data is in sync with the "utils dbreplicaiton status" command. You need to wait a bit before the report fully generates, initially it will only contain about 10 lines.
- Reboot the server
- Upgrade the system to the latest 6.1(5)SU3
i had to restore the  database thru drs. , replciation was fine
Create
Recognize Your Peers
Content for Community-Ad
