Adding end users in CUCM and Unity
lughmani1
Hi All,
In CUCM using web interface, you can add local end user under
User Management > End User > Add new
I was wondering if this was possible through RESTful API? if CUCM does not support API's what would be the equivalent CLI command?
Jaime Valencia
CUCM uses AXL as the API, CUC does provide REST APIs for different purposes.
java
if this helps, please rate
Why don't you use Bulk Administration Tab to add multiple users at same
time using CSV.
