Walkthrough Wednesdays
167
cparapally
Beginner
Adding external number to Corporate directory
Hi Guys,
Is it possible to add External PSTN numbers in Corporate Directory?
Say,
ABC Department - PSTN number xxx
XYZ Department - PSTN number yyy
When user searches and selects ABC department, it should go to xxx.
Can you please help me how to configure this?
Mady
1 REPLY 1
cnuche
Hi, the quick fix would be to include these entries under global directory, if this is AD integrated you cannot add these as contacts, only as a user, that way the user will show up on the corporate directory.
Now that if you know a little about html, xml, asp and LDAP queries you can create your own corporate directory, you just need to modify the xmldirectoryinput.asp file to point to a custom directory.
Content for Community-Ad
Spotlight Awards 2021
