05-14-2015 10:59 PM - edited 03-17-2019 03:01 AM
Hi guys,
I have a Mega cluster of 14 CUCM SUB and intend to add 2 more CUCM SUB to the max that Cisco allows. Before I intend to add it into the cluster, I saw there is a bug CSCub12922: "Add new subscriber to existing 8.6+ CUCM cluster cause all device reset" which say all device will be resetted.
I just want to confirm if it refers to all devices(phones, gateways, etc) under this new CMG(Call Manager Group) OR ALL devices in the cluster irregardless of the CMG they are assigned.
Any advice will be much appreciated.
tacl
05-15-2015 12:01 AM
This is documented under the following
https://tools.cisco.com/bugsearch/bug/CSCub12922/?reffering_site=dumpcr
Symptom:
Add new subscriber to existing 8.x CUCM cluster cause all device reset
Conditions:
Adding a new subscriber to existing 8.x CUCM cluster cause all device reset due to database update. Issue recreated in lab when "Prepare Cluster for Rollback to pre 8.0" set to both true & false. The symptom and logs are the same in each scenario
This is not a bug. The condition is applicable only to CUCM 8.6 and higher releases. Whenever a node is added to CUCM cluster , from CUCM 8.6 onwards , the phones belonging to that Call Manager group will be automatically restarted
These resets are soft reset, which means that if the phones are having an active call they will not get reset at that moment. This will only reset devices that are idle.
Manish
05-15-2015 02:43 AM
Thanks Manish. Does it means that only new nodes on existing CMG(Call Manager Group) devices are affected only or all devices in the cluster will be restarted?
05-15-2015 03:31 AM
Sadly "After you install a new node in an existing cluster, all phones that are registered to the cluster are reset."
This is documented here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/9_1_1/CUCM_BK_I05CD008_00_installing-cucm-91/CUCM_BK_I05CD008_00_installing-cucm-91_chapter_01.html#CUCM_TK_A9E74880_00
Manish
07-29-2015 06:23 PM
Is this bug going to be corrected?
07-29-2015 08:58 PM
It applies to 8.6 and higher versions, there are no options available to avoid it at the moment.
Manish
10-08-2019 01:13 PM
Does anyone know if this device reset, when adding a Node to the cluster still occurs in the 12.5 release version??
10-16-2019 04:10 PM
Paul,
According to what was posted above,
08-29-2016 07:09 AM
The part on the soft reset appears to have an issue in 9.1.2.12900-11. Adding a Subscriber last week reset all phones AND dropped - as near as can be determined - every active call. This is a great procedure to conduct during a known downtime, and at the least impacting time possible.
