i have been ask to connect one more E1 to my VWIC on my voice gateway , i think this extra E1 is basically a redundant line incase the first one fails correct?
in term of configuration changes i think i woud need to add another dial peer to direct outgoing calls from my company for example right now i have
dial-peer voice x pots
destination-pattern .T
progress_ind setup enable 3
no digit-strip
direct-inward-dial
port 0/0/0:15
controller E1 0/0/0
pri-group timeslots 1-31
so i would only add this "port 0/0/1:15" as in the new serial port and
controller E1 0/0/1
no digit-strip
direct-inward-dial
port 0/0/1:15
is there other configuration i need to add?
