Adding phones 7861 on cucm 9.1
abd88elhak
.Hi
i would like to add phones 7861 to cucm 9.1 but i didn't find this type on the liste
could you give me please the  packege needed to add this phones (download link)
CUCM version is : 9.1.2.10000-28
Jaime Valencia
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html
You really should know how to use the downloads site at cisco.com if you're a voice engineer, that's a basic thing you need to do on a regular basis.
java
if this helps, please rate
Rob Huffman
Hi there,
*EDIT - +5 to my buddy Java for beating me to the punch here :)
Support for the 7800 series with CUCM 9.1.2 was added with the installation of Device package 9.1(2) (11012-1)
Cisco Unified Communications Manager
Device Package 9.1(2) (11012-1)
Release Notes
From;
http://www.cisco.com/web/software/282074299/107387/cmterm-devicepack-9_1_2_11012-1_Readme.pdf
I would install the latest 9.1.2 Device Package 9.1(2)(13076);
Here is the path via CCO;
Cheers!
Rob
Unified Communications Manager/CallManager Device Packages-9.1(2.13076)
