Adding prefix to call history
CC Estelle
Beginner
Beginner
I've recently setup a CUCM server, which has an H.323 trunk to an Avaya system, which is where all outbound calls exit from.  My Cisco IP phones work fine if the user places a call. However, they are not able to go into their call history and hit redial for any external calls. The reason is because the call history only shows the area code + 7 digit number.  For them to make an outbound call, they need to dial 9 first.
How can I have the 9 show up in their recent calls?
Example: the user hits recent to see missed calls and the number shows as 212-256-1234, but to make the call, the user needs to dial 9-212-256-1234
Any help is appreciated
1 REPLY 1
Aeby Vinod
Participant
Participant
There are different ways by which you can achieve it, one way is discussed in the below thread:
https://supportforums.cisco.com/t5/unified-communications/cucm-10-0-how-to-translate-or-transform-add-prefix-for-incoming/td-p/2732957
Because the you would need to specify the CSS created on the number types (local, national etc) you want the prefix to be applied for.
Please rate if you find this helpful.
Aeby
Aeby
