Everything is installed via the SW upgrade option in OS admin
You can use the Software Upgrades options to perform the following types of installations and upgrades:
•Install/Upgrade—Use this option to upgrade the application software, install Cisco Unified Communications Manager Locale Installers and dial plans, and upload and install device packs, phone firmware loads, and other COP files.
•TFTP File Management—Use this option to upload various device files for use by the phones to the TFTP server. The TFTP server files that you can upload include custom phone rings, callback tones, and phone backgrounds.
Same process for any CUCM Linux appliance you might have.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
