185
Highlighted
Beginner
Adhoc Conference issue
I have Pub and 4 subscribers 2 for each site. when making adhoc conference from anysite using MRGL X with Avaya PBX conference works  but if i used MRGL Y conference connected but silent
MRGL X: contains 2 software CFB, MTP (subscribers of site X)
MRGL Y: contains 2 software CFB, MTP (subscribers of site Y)
IP Voice media streaming is activated on all subscribers
3 REPLIES 3
Highlighted
Hall of Fame Cisco Employee
Is there routing from endpoints to all CFBs?
Have you made sure that the codecs used are supported by your CFBs?
java
if this helps, please rate
Highlighted
Is there routing from endpoints to all CFBs?yes
Have you made sure that the codecs used are supported by your CFBs? yes g711alaw & g711ulaw
also i have only one region which is the default one
Highlighted
You can try bouncing the CFB and see if that makes a difference, otherwise, you'd need to take a look at some traces to find out what might be causing this.
java
