01-06-2020 11:55 AM
I have Pub and 4 subscribers 2 for each site. when making adhoc conference from anysite using MRGL X with Avaya PBX conference works but if i used MRGL Y conference connected but silent
MRGL X: contains 2 software CFB, MTP (subscribers of site X)
MRGL Y: contains 2 software CFB, MTP (subscribers of site Y)
IP Voice media streaming is activated on all subscribers
01-06-2020 12:01 PM
Is there routing from endpoints to all CFBs?
Have you made sure that the codecs used are supported by your CFBs?
01-06-2020 12:10 PM
01-06-2020 02:48 PM
You can try bouncing the CFB and see if that makes a difference, otherwise, you'd need to take a look at some traces to find out what might be causing this.
