Explorer
AIM-CUE not reachable by router
CM Express 7.1 with Unity Express on an AIM-CUE module in AIM slot 0.  Router can't reach the module.  Possible routing issue.  Can someone take a look and give me a clue as to what the issue might be?
All replies rated.
Everyone's tags (3)
12 REPLIES 12
Contributor
Your routing is correct
ip route 10.5.1.211 255.255.255.255 Service-Engine0/0
try ser ser o/o session and check if you can into the cue
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Please check the status of the service module, it could be down, and hence you are unable to ping
service-module service engine 0/0 status
Highlighted
Explorer
Thanks.  The module is showing as up.  I did the ser er 0/0 and go inot the cue.  I did a no shut and that seemed to shut it down.  Now console session is blank and does not react.  Any ideas?
Contributor
From cme
ser ser 0/0 reset
And check how is going
cc
Explorer
Here is the output of service-module service-engine 0/0 status
COSG-2801-CCME#service-module service-engine 0/0 status Service Module is Cisco Service-Engine0/0
Service Module supports session via TTY line 66
Service Module is in Steady state
Service Module heartbeat-reset is enabled Getting status from the Service Module, please wait..
Cisco Unity Express 7.0.2
CUE Running on AIM
Cisco Configuration Professional keep s saying the AIM module has been reloaded, please wait for module to reload and then discover again/
Contributor
So did you reset the module as i said to teh previous post?
Explorer
Yes but still at ssame point.
Contributor
ok
Now reload the module
Send the output from the cue
1) ser ser 0/0 reload
2) ser ser 0/0 session (take the output from the begin to the end and send it)
what is showing now if you get in the cue..is ofline or online?
Explorer
Booting: [#######################>...................................] 38% waiti    Booting: [########################>..................................] 40% waiti  Booting: [###########################################################>] 100% SYSTEM ONLINE TBA-CUE-TX-HT# *Sep 20 18:17:57.879: %FILESYS-5-CF: External CompactFlash removed Flash card inserted in flash. Reading filesystem on the device... Wait for the completion message before accessing device Filesystem read completed in flash. Device in flash available for use
Contributor
everything looks ok
can you describe now the problem?
can you ping the module
can you ping the cme from the module?
if  you got in the cue then the module is online right?
Explorer
DOH!  The problem was CCP.  It kept reporting that the router could not reach the modeul and still does say that but I can pinboth ways and opened a web browser to the AIM module and walah!  It opens up.  I must have miseed a step because I can't log in.  Where do I go to create that username and password?
Contributor
Cool
Now you have to proceed with the initialaization of cue gui
into telephony-service of cme
web admin system name admin password ??  ->config teh username and the pass
Now  go to cue gui and continue with the initialaization
Content for Community-Ad
August's Community Spotlight Awards
