ā05-26-2013 05:50 AM - edited ā03-16-2019 05:31 PM
I want to know which card do I need to connect my VG 2951 router /UCM 7.0 to Alcatel Pabx
I've been told that they need E1 with signaling qsig+
available cards:
HWIC-1CE1T1-PRI
VWIC-2MFT-E1
NM-HDV
which one will be better
regards,
ā05-26-2013 05:56 AM
You need to use VWIC3-2MFT-E1 card for QSIG integration.
regds,
aman
ā05-26-2013 06:14 AM
thanks,
another thing, because i have only one SM free port, can I use it with :
SM-NM-ADPTR and NM-HD-2V
ā05-26-2013 06:42 AM
That is not a good solution, Use correct advice given above already by Aman.
