Showing results forĀ
Search instead forĀ
Did you mean:Ā
Walkthrough Wednesdays
237
benhamzagi
Beginner
Alcatel qsig requirements
I want to know which card do I need to connect my VG 2951 router  /UCM 7.0 to Alcatel Pabx
I've been told that they need E1 with signaling qsig+
available cards:
HWIC-1CE1T1-PRI
VWIC-2MFT-E1
NM-HDV
which one will be better
regards,
3 REPLIES 3
Aman Soi
Advisor
You need to use VWIC3-2MFT-E1 card for QSIG integration.
regds,
aman
thanks,
another thing, because i have only one SM free port, can I use it with :
SM-NM-ADPTR and NM-HD-2V
That is not a good solution, Use correct advice given above already by Aman.
Content for Community-Ad
Spotlight Awards 2021
