01-08-2014 12:10 PM - edited 03-16-2019 09:09 PM
Is it possible to have 4 extensions ring at the same time when someone calls a specific pstn line. I need to know how to do this. Currently we have it setup so only one extension rings at a time.
Thanks.
Solved! Go to Solution.
01-08-2014 01:14 PM
Refer to this link for paralell blast option . If this help
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1145800
01-08-2014 12:19 PM
This can be done using a hunt pilot and line group with broadcast . The config depends on what system you are running. (CUCM/CME)
You can also just add a new line containing the same DN to all the phones that you wish to ring.
Gareth
01-08-2014 12:21 PM
I am currently running CME 8.4 on a cisco 3800 router. Do you have a link where I could say find an example of how this is done.
Thanks.
01-08-2014 01:14 PM
01-08-2014 01:18 PM
Thanks a lot for reply Nadeem its exactly what I was looking for.
